Re: NX 11 release?
Great - thanks a lot!
Re: NX 11 release?
NX11 is now available on the download portal. It's been up since the 29th of July
Re: NX 11 release?
Without wishing to appear ungrateful for the latest NX11.0 release - does anyone know when we might expect a MR for NX11?
thanks
RIch
Re: NX 11 release?
thanks
RIch
NX11.0.1 is tentatively scheduled for January 31, 2017.
Ben
Re: NX 11 release?
Thank you Ben.
Compatability with Teamcenter is of course my next question.  The GTAC matrix lists NX11.0.
At what point between now and January 2017 would that information be released?
Rich
Re: NX 11 release?
Rich,
Does the Product Compatibility table give you sufficient information?
https://docs.plm.automation.siemens.com/tdoc/nx/11/release_notes/#uid:index_xid920445:id1264341
If you need something more than this please be more specific.
Ben
Re: NX 11 release?
Honored Contributor
Honored Contributor
FWIW, my test install of NX 11 mp01 is working with Tc 10.1.2, which it's not supposed to, per the docs. ymmv
-Dave
Re: NX 11 release?
Thanks Ben and Dave,
Its all helpful information.  Specifically I would be looking for the latest release of NX as of Feb/March 2017, to be compatible with Teamcenter 10.1.5
Rich
Re: NX 11 release?
Hello @DaveK,
About the combination you are using, This might well just work, connecting NX to TC. But there is a good chance there are still bug with this combination, that are solved in later versions.
Also possibly not all functionality might be working (correct). There is a reason why there is a minimum version given Smiley Very Happy It's nust just done to keep you busy.
So as said, it might work, and might be good for inital testing, please do not use  it in production. Also whenever you log an issue witht his combination, the first question we would ask is: "could you please upgrade to the combination that is certified". This might save you some time!
Kind regards,
Dennis
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
Re: NX 11 release?
Hello @RichB,
Officially you would have to wait untill NX 11.0.1 is released, and with it, you should find the Certified TC version(s). But I'm checking with development if we have anything planned. But remember that as long as the new MR is tested, bugs can be found and fixes can be added to Newer versions of TC, so no guarantees. Should I receive more info, I'll let you know.
Kind regards,
Dennis
Dennis de Brouwer
