NX 8.5 Crashing
Hallo we are having a problem with NX 8.5 crashing. Log files aren't showing something special (ERROR: Unhandled exception: 0xc0000005)
After searching the internet several things were listed as solution but none of the worked by me.
Do you have any ideas or checklist what i can go through so that the problematic can be solved.
Thanks in advance.
Re: NX 8.5 Crashing
Hello @SLR,
As explained in an other answer to you, you can use our solution center:
https://solutions.industrysoftware.automation.siemens.com/result.php?sort=desc&p=1&q=%22ERROR%3A+Unh...
But quickly going through the results from there. It is a pretty general error. It is always useful to know more about the contect... What are you doing at the time of the error. What is NX doing just before the error? (You might know more from the lines that proceed to this error.)
Or report this issue to GTAC, upload the syslog file of the session and the details you know around this issue.
I hope this helps.
Kind regards,
Dennis
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
