NX 9 MOLD WIZARD ERROR
I AM GETTING ERROR WHILE WORKING ON MOLD WIZARD.THE ERROR MESSAGE IS ATTACHED.
PLEASE SUGGEST SOLUTION.
Re: NX 9 MOLD WIZARD ERROR
Hi @rahul83,
The warning you received: "Encountered unexpected NULL pointer.  See system log for details" is a generic message.  To get a better understanding of what might be causing the NULL pointer, select "File > Help > Log File" and scroll to the bottom of the log.  If you're unable to determine from the log file what is causing the problem, and it's repeatable when you restart NX, please consider contacting your VAR for support or your local GTAC Support office.
Regards, Ben
NX (v17 - 1876) | Teamcenter (9 - 12)
