NX 9 and Teamcenter: Drawing's Parts List Not Updating ?
Hello
I changed the pieces numbers ( those balloons in NX ) in Teamcenter's Structure Manager (Send to -//-).
  • The TC assembly drawing file was already made earlier before making "this PC NO change" and when I tried to update / refresh the Parts List no changes appeared in the Parts List ?
  • Do I need to create a new drawing.DWG for the assembly and delete the old drawing ? [ Might be somehow corrupted parts list : link cut to TC ? ]
  • What can I try to make the old drawing's parts list refresh its PC NOs ?
4 REPLIES 4
Re: NX 9 and Teamcenter: Drawing's Parts List Not Updating ?
I tried to create a DWG(2) second drawing file and it showed correctly the PC NOs.
- Any ideas if it is possible to make the original drawing file update its parts list ?
- If not I have to create all views and measures again to the second new dwg.
Hi @12131444,
What if you create a copy of the drawing sheet in the first drawing file, delete the parts list and recreate it. Check once how it gets created.
I copied and pasted the sheet on .dwg1 but same happens.
- The newly created .dwg2 works but I need to create all views and such again.
I created a new .dwg2 and placed new views and dimensions, but now when I try to delete .dwg1 from Teamcenter it says "Unable to delete dataset" ?
