NX CAD | Assembly Constraints by Expressions
I need help to know if it is possible and how it is done,
Control the constraints in assembly through expressions as it exists in part mode for the features
constraints through expression as it exists for features
Re: NX CAD | Assembly Constraints by Expressions
Yes. Check the article Assembly Driven Constraints
You can also define the different arrangements and make assembly constraints arrangement specific where expressions can also be used.
Ganesh Kadole
This is not what I intend, I need to suppress or unpress constraints controlled by expressions.
I don't believe that's currently possible.
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Tel: +1 (602) 441-0683
taylor.anderson@siemens.com
