NX Cabling Cableways and Conduit
Hello gys,
i struggle a bit with the NX Routing Cabling part. I tried to figure out how the Cableway Properties and Cableways tools work, also what is the difference between raceway and conduit. ( ok i see in the library that conduit is more like round fitting stuff)
The main Problem is i cant find any trainings, allways only harness creation but for raceway and conduit not much, even the help does not help me at this point.
and it is equal if i try with NX10 or NX9.
If i wanna use Cabelways layout it let me no select any object.
If i use Cabelways properties and if i give a fill percatage it does not affect it if i make some cables on it.
Sorry im lost :-)
Cheers the Cable"noob" guy
Re: NX Cabling Cableways and Conduit
Meanwhile i found the soultion by myself. The problem has been named USER...
If you wanna see cable layouts you must habe a cable :-)
cheers
