NX Co-Simulation
Dear all,
While doing a NX Co-Simulation, I encountered a problem, that the dynamic result was not the same as the one I got from a "normal" Dynamic/Kinematic simulation.
My procedure was that I just excited my system with a sine wave with Simulink and increased the frequency (amplitude was the same). But against my assumptions, the reaction forces didn't increase. So I decided to do the same simulation with the NX integrated Dynamcs/Kinematics tool. There the forces rised, because of the higher acceleration from the higher frequency.
Had someone else a similiar problem or am I doing something wrong?
Kind regards
Chräbi
Re: NX Co-Simulation
Hi @Chräbi,
You might get a better response if you post your question in the SimCenter forums, unless you're using Mechatronics.
Regards, Ben
NX (v17 - 1872) | Teamcenter (9 - 12)
Hi Ben,
Thank you for your advise
Kind regards
Chräbi
