NX Drafting. Export shaded PDF problem.
Hello people!
I have encountered some strange behaviour.
(See attachment)
If I in drafting app is trying to export pdf then a strange thing happens: when view scale is 1:1 - it's OK. If the scale is 1:5 - there is no output and pdf is blank...
Can you test this file in your systems please. Maybe I have some wrong settings...
4 REPLIES 4
Re: NX Drafting. Export shaded PDF problem.
Hello.  The problem appears to be that when the view is edited to a scale of 1:1 the view boundary extends beyond the drawing border.  If you edit the boundary to fall within the drawing border then the PDF exports successfully at a scale of 1:1 and 1:5.  I've attached your part with the edited view border.
Regards, Ben
It's working. but I can not understand how to edit view borders?
Hopefully the attached movie will help.
Regards, Ben
Thank you.
Still some errors it rendering but at least there is a shaded image after all.
