NX Drafting Sheet Numbering - Start Number Choice
The part I'm working on has multiple drawing partfiles, due to its sheet number size (some of our drawings clock in at around 90ish sheets). I want to know if there a way of starting the sheet numbering in the second and third partfiles from (e.g.) 30 and 60, so I can use the <W@$SH_SHEET_NUMBER> attribute to control the sheet numbers within the drawing sheets rather than manually modifying it? When I've tried to change it, it lists the error of 'not being in sequence'.
Re: NX Drafting Sheet Numbering - Start Number Choice
Siemens Legend Siemens Legend
Siemens Legend
Hi @Pigeon ,
If you change Initial Sequence Number in Drafting Preferences, sheets number are accordingly changed.
Samadhan
NX Help Links: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
Thanks, that has worked perfectly!
