NX Drafting
Hello Everyone,,
This is the error one of my customer is getting when he is going into drafting application
drafting error.JPGwhat Might be the issue??? is this because he set his layer settings to invisible or any other settings???
4 REPLIES 4
Re: NX Drafting
This warning is presented when the layer containing the default title block (which is usually layer 256) is set to invisible.
Re: NX Drafting
Oh..so we need to set it to visible right?
Re: NX Drafting
Yes, set the layer to Visible to see the table and remove the error message. Set it to Selectable if you want to edit the table.
Re: NX Drafting
Thanks deckhoff 🙂
