NX-ELECTRICAL ROUTING - SEARCH VIEW
Hi guys,
I was wondering if there is a way to showing the attributes of a component in the "Specify item" - "member view"
I'd like to have the by object: od, color.ad so on. is it possible?
I know that with a rigth clik i see the "information".
Thanks alot!!
Daniele
Re: NX-ELECTRICAL ROUTING - SEARCH VIEW
Hi Daniele,
I have no idea if this is possible or not but you can always filter your search based on different parameters.
Will this help your case?
Best Regards
Kapil Sharma
