NX - ELECTRICAL ROUTING
Hi guys,
I d like to define a label on cable that be deformable with cable. I waS thinking a Overstock but how can i define the text on it??
Re: NX - ELECTRICAL ROUTING
Hi Daniele,
Apologies for drifting away from the subject but i guess it will be better to provide this information in Formboard drawing  using Formboard annotations instead.
Coming back to the questions you raised.. However i could write the text using Curve on Face option for text (isoparametric curve is built for curve ref.) but to my understanding the moment you will change the stock ...this will disappear...so not so robust way of doing the same...if you need this label just for visualization...then use DECAL instead.
Thanks and Best Regards
Kapil Sharma
