NX HELP ISSUE
Hello Everyone,
     I am unable to access help i'm getting getting the below error.
Currently i'm using java jdk 1.8.0_45 and JRE and using NX11 even i've updated with latest MP.
I've set the variables for path and ugii_java_home
Re: NX HELP ISSUE
Siemens Genius Siemens Genius
Siemens Genius
Have you also installed the documentation server?
NX Design Apps Documentation & Courseware Manager
Re: NX HELP ISSUE
Yes doc 2.0
Re: NX HELP ISSUE
Did you do the following?
  1. installed JRE 1.8, preferably update 131
  2. installed SPLM documentation server, preferably v2.1
  3. installed NX help
If you haven't done one of these steps, start from that step and proceed.
Re: NX HELP ISSUE
Ok I will update it to 131 ..help I've installed
