NX Hole Table.
When I try to create a Hole Table, only is possible to select any hole. Is there any preference to configure for solution this problem?
Re: NX Hole Table.
When using the hole table you need to make sure that you have fully loaded your part.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
