NX JOURNAL to find drawing file and exort PDF
I want to know is there any option on NX journal to find and export PDF drawings from a big assembly (contains min component of 500+), i want a jounal which automatically search the drawings and export the file as PDF for complete assembly.
Kindly hepl me to find this
Re: NX JOURNAL to find drawing file and exort PDF
There is a journal on the solution centre that does this.
create pdf of all drawing sheets in all open parts
Suresh
Production: NX10.0.3 Developing: NX11.0.2.7, NX12.0.2, NX1847,
Development: C++, C# .Net, VB .Net, KF
When i open the hyperlink it shows that, Access to the requested resource
is forbidden.
*Disclaimer:* *The information is intended to be conveyed only to the
designated recipient(s) of the message. If you have received this
communication in error, you are requested to notify the same immediately by
replying to the message and deleting it from your computer. If you are not
the intended recipient, you are hereby notified that any dissemination,
use, distribution or copying of this communication is strictly prohibited
and may be unlawful.*
