NX LICENSE ERROR -103
I am getting this error for a node lock license. It worked after a few times but again facing the same issue.
Re: NX LICENSE ERROR -103
You have a standalone (workstation) copy of the software. Standalone copies are designed to be operated while you are physically present at the computer. By design, it is not possible to remote in and run a standalone copy of the software.
If you wish to use Siemens software with Terminal Services, Remote Desktop, or other forms of remote access, please contact your Siemens sales representative to convert your standalone license to a concurrent network license.
RRG
Thank you @RakeshGarud
... It worked
