NX MCD: Create sequence of operations example
Siemens Legend Siemens Legend
Siemens Legend
Hi NX Design Community,
I have created a small example of an XYZ-Portal (from Schunk) with a basic sequence in Mechatronics Concept Designer (MCD).
MCD uses "Rigid Bodies", "Joints" and "Controls" to define basic motion elements.
The "Operations" in the "Sequence Editor" can be used to define the motion sequence.
The following Video shows how to create a basic time based sequence and control the 3 axises of the XYZ-Portal
(view in My Videos)
This example is provided with and without the MCD operations/sequence for NX11.0 (see Attachment).
Best regards
Viktor
