NX MCD
Hello everyone!
I am trying to connect NX 11.0.0 with virtual CPU-1500.
In TIA portal, I create a controller with OPC UA server and then I upload it to PLC SIM Advance virtual controller.
Before I’ am trying to connect CPU with NX, I‘ am tested id with opc client - OPC scout, and the connection was fine - i can read and write variables from CPU.
Next I ‘am trying to add my OPC server to NX (choose remote server and add controller ID with port to server ProgID), but I received the warning "the server not reachable".
Can U help me with this problem? Maybe NX didn't support OPC UA?
Re: NX MCD
Hi Michail!
OPC UA will be available with NX 12.0 in Mechatronics Concept Designer.
But NX 12.0 also offers a direct connection type to PLCSIM Advanced, which is way easier. It doesn't require a Signal Server at all.
Johannes
Re: NX MCD
Thank you, Johannes for help.
Is it possible to ask my questions about configurated OPC DA server here ? I'have some problems with this task.
Re: NX MCD
prompt message:can not get service id
I met this problem too.Do you have a solution
System problems or setting?
Re: NX MCD
How can i find the document about the connection between PLCSIM Advanced and NX 12.0,Sir? Can you help me? I am a student and i'm trying to do that task. Thank you.
Re: NX MCD
