NX - No modeling template
Hi, I have BIG problem.
When I try open my NX 10 I have no model templates. It works well but suddenly it stops. Pls check attachemnt. I Uninstall all NX on my computer and then reinstall NX 10 again (2 times) and it still doesn't work. templatesblank.jpg
Re: NX - No modeling template
Are you able to locate the pax files in your installation folder?
Kapil
@lukipap: There are 3 more topics with same content posted by you. Please delete those so that it will be easy for other users to help you.
Ganesh
sorry, it is because I have problem with IE today...
Hi, I have pax file in correct folder. Should I have check something inside this files?
Thanks for resopnd !
OK, I have found mistake in envirement variable. The path was wrong and chose NX 11 folder instead of NX 10. Thanks for help anyway!
best regards
Re: NX modeling no template
Siemens Genius Siemens Genius
Siemens Genius
Have you checked that they actually got installed?  ie is the directory containing the templates present?  Are the templates in it?  Do you have any environment variables present that are controlling where NX looks for templates?
Re: NX no modeling templates
You can start by trying to find out what pallet files it is looking for. In the log file search for the .pax extension and see what it it trying to read in. If the pallet files are find look at them and see what .prt files it is calling on. Make sure those files exist. That is a good place to start.
BTW, you the same question twice.
Scott
Community Manager
Just letting you know, I have merged your posts and the replies you have gotten so far into one thread that way it's easier for you to get answers from people in the forum Smiley Happy
Amy
Community Manager, Solid Edge
Become a Solid Edge Certified pro today!
