NX Parts List issues
PLM World Member Genius PLM World Member Genius
To All:
I have an NX assembly that consists of metric and english parts in a metric assembly template. I have added this assembly to a metric Master Model Drawing and created a parts list. However, only the metric parts are showing up in the list, none of the english/inch (sheet metal) parts are showing up and nothing I try seems to be working.
Any ideas?
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Budde Sheet Metal Works, Inc.
Windows 7 Professional x64 SP1
Solid Edge V20
NX11.0.1
TC10.1.5 32 GB RAM, nVIDIA Quadro K4200
Re: NX Parts List issues
I had to test this just to be sure Smiley LOL but it should work without any hiccups.
Things to check:
1) Use Edit Levels to check that the metric components highlight in the Part Navigator.
2) Check the that attributes REFERENCE_COMPONENT, PLIST_IGNORE_SUBASSEMBLY or PLIST_IGNORE_MEMBER have not been assigned to the components not listed.
3) Did you use a Parts List Template?  If you did, try the default parts list to see if everything is listed.
Regards, Ben
NX (v17 - 1872) | Teamcenter (9 - 12)
I think I have narrowed it down to our third party tools for TC and NX. If I run native mode, it all works.
Thanks!
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Solid Edge V20
NX11.0.1
