05-13-2015 04:22 AM
Can I remove the text on the ribbon bars?
By the way, I am using NX 10.0
Jahnsen
Solved! Go to Solution.
05-13-2015 04:52 AM
Hi Jahnsen,
Do you mean "text below icon" option to toggle ON and OFF ?
BR,
Mak
05-13-2015 04:58 AM
05-13-2015 05:04 AM
Please refer response on my post "How to customize ribbon bar without text below icon". It should be available in NX 10. If not, contact GTAC.
05-13-2015 05:11 AM
05-13-2015 11:31 AM
In order to remove the text from Icons on the Ribbon, you must first enter Customization and then right-click the icon-of-interest to get to the various size and text options for that icon. After editing, be sure to save your role so that any changes will not be lost.
05-15-2015 03:27 AM
Hi John,
Would you please post step by step procedure with images ? I am not able to find the way using NX Documentation or the way youmentioned.
I am using NX 9.0.3
05-15-2015 03:38 AM
Hi Mak,
This is how you do it,
rightclick the ribbon bar.
select customize, the customize dialog box appears, while the customize dialog box is open, you can now customize your ribbon bar. remove the text if you want, or make the icons larger.
05-15-2015 03:43 AM
If I understood it correct, I need to activate 'customize' dialogue box first by right click.
While 'customize' dialogue box is still open, AGAIN right click on ICON / RIBBON for which I want to turn off TEXT !!!
If I remember corrct, this explanation is nowhere in the DOCUMENTATION !! correct me if wrong.
Earlier versions have all settings in "customize' dialogue box and did not understand this NEW approach !!
BR,
Mak
05-15-2015 03:54 AM
