NX command window with Win 8.1
Honored Contributor
Honored Contributor
It appears some Windows update, or something, has jacked up my ability to use ugiicmd.bat.  I put a short cut to it on my desktop, and it's worked for the last year or so, since I went to Windows 8.1, but now the dos window flashes on the screen, and is gone.
Any clue as to what I need to change?
-Dave
3 REPLIES 3
Re: NX command window with Win 8.1
Open a standard CMD window and type in the path to the ugiicmd.bat, hopefully you'll see the error that otherwise disappears as the window opens and closes...
Production: [NX8.5.3.3 MP11 64bit] Testing: [NX12.0.2 MP1]
Honored Contributor
Honored Contributor
Good idea, but nothing.
-Dave
Honored Contributor
Honored Contributor
I ended up following this, again, and creating the new Tool Bar.  From that tool bar, I created a new desktop shortcut, which when you look at the properties, appears identical to the original, except that it works, lol.
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&file_type=text&q=ugiicm...
-Dave
