NX drawing templates
Can anyone suggest how can we use NX9 drawing templates and customer defaults for NX7.5
Background,
For one of our customer we have customized drawing templates and customer defaults like visible lines, dimension text color, height and so on... These settings are carried out for NX9.
Now we have received one project, where we have to execute it in NX 7.5.
Hence I was planning to use the same settings which are carried out in NX9.
Yunus
Re: NX drawing templates
Hello @Yunus,
Customer default you can export, and import, and provided that the customer default, that is set, already existed in NX 7.5 this should work just fine. Of point your user dit to the dpv file you want to use.
But the real problem will be in the template parts. The template files for NX 9.0, that are actually part files, cannot be opened in NX 7.5, so you would have to set this up again in NX 7.5.
Kind regards,
Dennis
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
Thanks for your reply.
Yunus
