NX fails to find part family template to generate missing members
Hello everyone!
Has anyone came across this problem? I have a fastener library in the organised folder structure with one main folder for templates and another for generated members. I tried to remove generated members from the members directory in order to enable NX to identify them as missing and regenerate. The problem is that NX fails to find some of the templates, but not the other. Those that it finds it regenerates without problems, those that it does not - it does not. I can't see a pattern here because all templates are in the same folder structure and work well. It is only regeneration of missing members that I have problems with . Does it sound familiar? Has anyone experienced the same before?
