Re: NX functionality questions and enhancement requests
@cowski1
I created 002_XYZ at last.
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
That is interesting. You build all these toolbodies into a component. I'm an old school guy so I don't know if this has been superceded or not but have you looked at user-defined features-UDFs? Like I said not a pro on the use of these..way back when we used them quite extensively.
@mike_fdo
Perhaps it has finally been fixed. Does it reflect the same order in the "replace reference set" dialog?
@cowski1 Yes, they are in the same order.
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
Mark one off the list, I guess.
Is this a drag and drop interaction?  I don't see and buttons to adjust the position in the NX 11 dialog.
@lthompson
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
