NX licence error VPN Windows 10
I've been using NX 10 in Windows 7 succesfully with licencing trough VPN to my company. I upraged to Windows 10 and when trying to launch NX, following error occurs: "NX licence error: Licence server machine is down or not responding. Check that SPLM_LICENCE_SERVER is set correctly. [ -96]."
I've tried to reinstall NX and VPN client but it makes no difference. I've tried to disable Antivirus and Firewall. I've tried to google similiar problem but haven't found anything suitable.
I'd be very thankful if someone has a solution for this!
10 REPLIES 10
Re: NX licence error VPN Windows 10
if you use command prompt to ping the server give this a time out or can your system ping the server machine?
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Hello, thank you for answer!
I tried to ping the server found out that the server name had to be the longer version with domain. Strange thing but now NX starts normally. Thank you!
oke strange. nothing changed on the IT site?
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Nothing has changed in my companys end if that's what you meant? Maybe firewall is changed somehow in windows 10, altough I tried to turn it off in the first place.
that can be. butt good to hear that NX is working.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Good evening,
I have the same problem when trying to open NX. So I tried to ping the server and it gives a time out...
Do you have any idea why i have this problem while it worked perfectly last week.
Thank you
Is your license on a server? Its always possible that your Connexion to the server is lost. Of the server is down.
It can also be your firewall that blocks the server
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Note your firewall (or VPN software) may be blocking ports too.  By default, 28000 needs to be open.  But it also uses a few other ports (I forget exactly which).  If you have (add) a "PORT=" on the VENDOR line in your license file, you can specify the "other" port that is used (e.g. "PORT=28001")
Check your license server log file - is there ANY message from the client?
Is the client specifying the license server using FQDN? (xxxx.company.com) instead of just the host ("xxxx")?
What if you use the IP address of the server instead of  the host name (SPLM_LICENSE_SERVER=1.2.3.4@28000)?
When on VPN (if you allowed) can you "remote" into the license server computer?  (e.g. "mstsc.exe" or equivalent)?
