NX not run and no reactions
I was formatted my PC. And I re-installed NX 12.
But, NX 12 not run and no reaction also.
LMTools is running normally.
Please advise to me.
Thanks!
12 REPLIES 12
Re: NX not run and no reactions
Hi @LittleWillie76 ,
I am assuming you are running NX on supported windows platform.
Do you see NX process running in the windows task manager?
Also check the status of 'ugraf.exe' under details tab of the task manager. Does it show Running/Not Responding ?
Hi Mr. Granesh!
Thanks to your attention!
I using Window 10 Pro 64 bits.
I checked that ugraf.exe running condition in windows task manager.
But, even if I double-click NX icon, but ugraf.exe not appears in windows task manager.
Little Willie 76
You can try running NX after restarting the PC, if you haven't done.
Samadhan
Hi Mr. Samadhan
I also rebooted my computer several times.
But, it does not work.
Is this issue relate with network or security programs?
Little Willie 76
It can be.
I would suggest to contact GTAC team for this issue.
Samadhan
Hi Mr Samadhan!
Thanks to your advice!
I will contact GTAC team for this issue.
But if you have good idea for this issue, please advice to me!
Little Willie 76
@LittleWillie76
Was NX12 working prior to formatting or Is it fresh installation?
Does installation completed successfully?  Just in case you may try to to repair installed version or complete reinstall. Smiley Wink
Hi Mr. Ganesh!
I used Windows 7, but I changed to Windows 10.
Of course, I was formatted my PC before install Windows 10.
And then I installed NX 12 on my PC.
But, NX 12 does not run and any reaction.
Little Willie 76
In addition
Host Name, Composite ID, Mac Address does not changed.
