NX preview in Teamcenter disappeared ?
Hello
NX part preview in Teamcenter disappeared ?
- It was there previously but when I restarted the computer then no preview was available.
- Happened to someone ? Now I have no preview. Tried restarting TC and everything.
- I used it normally and didn't change anything when this happened.
Re: NX preview in Teamcenter disappeared ?
I opened the part and saved it. Now I can see the preview.
  • Is there a way to create a preview without opening and saving the part ?
If you create an item in TC and add UGMASTER dataset to the item revision, you will not be able to see the preview image in the overview tab of summary unless you open that UGMASTER dataset in NX and save it with or without adding any feature/geometry. You will be able to see the preview.
