NX projection method in drafting
Hello All
I created a drawing without checking the projection method. It was supposed to be third angle projection but I created it in first angle projection.
So i decided to change them by double clicking the sheet and changing the projection method in settings. When I check the settings of the sheet, it shows third angle projection. But the drg views are not getting updated to the choosen projection method.
The drg was created using "View Creation Wizard".
Could anyone tell what am I missing here ?
Attached images for before and after the setting change
Thanks in Advance......
Sathyaraj C
NX9.0 | windows 7
Re: NX projection method in drafting
Do you see the green ticks in your drawing? If not, you will need to update your sheet by right clicking on Sheet and clicking Update.
EDIT: removing my question as I re-read your instructions
Alex
