NX rebuild/update problems
Hello All ,
I'm currently working on NX10(NX 10.0.0.24 version) model that has more than 1000 features. Every time if I edit any feature, all features get updated. This will take more time and sometime features may fail.
Is there any way to come out of this situation?.I heard there is an option called Freeze in solid works which will isolate other features while rebuliding.
Please suggest me guys.
Thank you,
Devaraj.
3 REPLIES 3
Re: NX rebuild/update problems
You can use 'Delay Model Update'
Menu > Tools > Update > Delay Model Update.
Firstly check in your Customer Defaults in Gateway-General-Part that Save Data for Feature Edit is set to Fast Rollback. (Have set and saved this exit NX, will see benifits after next update, save and reopen of a part).
To have behaviour similar to Freeze I think you will have to upgrade to NX 11.0.1 and then you can use the Delay Part Module functionality .
Steve V
you can use synchronous modeling tools in the end of your design to make changes.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
