NX supressed elements in TC BOM
Is there a way to avoid NX supressed elements to appear in TC BOM? I hide them in structure manager but I can still see them in the view folder and they appear when creating reports in excel.
Re: NX supressed elements in TC BOM
Did you try to set them to Reference only?
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
I don't know about TC but in drafting, this would be te way to tell NX not to call it in the part list.
I assume that
Hi Javiduc
In Teamcenter Structure Manager under the View Tab there is "Show Suppressed Occurrences"
This will hide all the Nx supressed parts , a Bom can then be exported from this and it will exclude all the Nx supressed parts, Alternatively you can do it with arrangements set up and managed in side nx, But then again in structure manager you can toggle on and off the different arrangements with the Yellow blocked arrangements icon inside the structure manager application in Teamcenter.
Matt
