NX10: Drafting: Angular Dimension - Line Method ?
Hello Community,
did anybody already find the pre NX10 feature:
Angular Dimension Line Method (see picture) ?
Where on earth is that in NX10 now? Again everything well reorganized for a higher work output. :/
Many thanks
Re: NX10: Drafting: Angular Dimension - Line Method ?
In Angular Dimension, you have to use Selection Mode as 'Vectors and Objects'
I am not sure, but from NX 9 this has been changed.
Ganesh
Siemens Genius Siemens Genius
Siemens Genius
Have you looked at Angular Dimension, Vectors and Objects Mode?2017-03-22 09_12_16-NX 10.0.3.5 - Drafting - [dwg1.prt (Modified) ].png
