NX10 Error on Part Family Excel link
Hi, after updating both Excel (to 2016) and Nx (to Nx10.0.3.5) I cannot start the Part Family spreadsheet, and I get an internal error warning (COM error code 80004003). Excel starts correctly from the Expression menu. Thank you for helping with suggestions
13 REPLIES 13
Re: NX10 Error on Part Family Excel link
Officially, we have not yet certified Excel 2016 to be used with any version of NX.  The newest version of Excel that NX 10.0 has been certified for use with is Excel 2013.
Note that this is covered in the Release Notes included with the installation of NX 10.0..
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Thank you John for the information.
Do you know if Excel 2016 will be certified for NX11?
Won't know for awhile yet, but I'll ask around and see if anyone knows what the plans are for certification.
Irvine, CA
I am using geometry optimization in NX Nastran (NX 11.0). While solving optimization setup, I am not able to connect with spreadsheet (MS Excel 2016). It shows error "COM error code 800401fd" everytime.
I have gone through the above posts. Is there any solution for the above problem ?
Thank you in advance.
Vimal Patel
not that I know of.
I have downgraded to Ms Excel 2013
It looks like Excel 2016 is certified for NX 11.
Excel Certification for NX 11
It is not included in the release notes for NX 10. NX 10 only shows up to Excel 2013.
Scott
Thanks Scott for the reply.
I will try using NX 10 with MS Excel 2013 and will let you know if it works or not.
Vimal
Scott
Vimal
Thanks Laurus. I will also try using NX 11 with MS Excel 2013
