Re: NX10-Using Expressions in Assemblies
I copy the folder and right click on each part and rename them. To properly change the file names, I just have to open the main assembly and "save as" into a new folder and click each component and do the same thing.
Simple enough! I will give this a try, and if I have any issues I will let you know.
Thanks for your help I appreciate it
If you do this a lot you might want to investigate the assembly clone functionality.
It will do all the files together, inlcuding updating all  the IPEs.
use command finder to search for "create clone assembly"
Thanks for this option it worked great!
Took me a bit to figure it out but I got it to work.
Thanks for the suggestion
Don't forget to make your question as answered!
hi Anderson,
My self Naveen working at Siemens. I followed your procedure to create the expressions in Assemblies. But, i am not able to create the expressions in assemblies. Can you share a document which gives detailed procedure how to create Expressions in Assemblies. It will be more helpful for my work.
My email id: naveen.km.ext@siemens.com
Hi, Naveen.  Not sure I fully understand your request.  I'll contact you privately.  Thanks!
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Tel: +1 (602) 441-0683
taylor.anderson@siemens.com
Hi Anderson,
Thanks for your reply,
These are my queries:
  • Needed detailed procedure how to do the parametric modeling in NX 10 for Assemblies containing more than 15 sub-Assembly  parts.
  • Needed to generate the Expressions for Assemblies using Interpart Expressions tool.
  • What are the different steps to be followed to create the parametric design.
[This conversation has drifted far from the original post, and will be handled privately.]
Taylor Anderson
