NX11.0.2 Component Information Popup
Does anyone know of a variable or setting to make the object information popup as shown in the image below any less transparent?  When trying to use this to quickly view component information in an assembly with a few dozen components, the transparency makes it very difficult to read.
Thanks!
Tim
NX 11.0.2.7 MP11 Rev. A
GM TcE v11.2.3.1
GM GPDL v11-A.3.7
4 REPLIES 4
Re: NX11.0.2 Component Information Popup
Hi @TimF
I couldn't find anything in the Customer Defaults or within the Customize commands.  I asked the developer responsible for some of these popups and he could find anything.
Please consider opening an ER with GTAC (I couldn't find any existing ones).
Regards, Ben
NX (v17 - 1876) | Teamcenter (9 - 12)
Thanks, @BenBroad - will add it to my to do list.
Tim
GM TcE v11.2.3.1
GM GPDL v11-A.3.7
Hi @TimF
I received confirmation from development that this is hard-coded into the software, so you'll definitely have to open an ER for this.
Regards, Ben
@BenBroad wrote:
Hi @TimF
Regards, Ben
@BenBroad,
Thank you for the additional info - will take this into consideration when I get some free time to log a few ERs / calls.
Tim
GM TcE v11.2.3.1
GM GPDL v11-A.3.7
