NX11.0 basic curve command appears shadow. Ask you to help answer. Thank you
Two versions of the same computer installed NX, the basic curve of the NX10.0 command to use the normal, NX11.0 basic curve command appears shadow. Ask you to help answer. Thank you
Re: NX11.0 basic curve command appears shadow. Ask you to help answer. Thank you
Builder
Builder
Hello@finder
which system are you using!!!!!!!
Describe the configuration.......
Warm Regards
Thomas Roman
Machine Designer
Hello @Thomas_Roman
System I'm using Win10 Pro X64, a system also installed the two software, NX10.0 is normal, NX11.0 not normal; please help. Thank you!
Builder
Builder
Hello@finder,
which type of graphics card & etc configuration
Warm Regards
Thomas Roman
Machine Designer
@Thomas_Roman
My chip is that, as shown above. NX 10 display properly, NX 11 is not normal to ask what is the reason this particular? Thank you
Builder
Builder
hello@finder,
as our discussion a,i already faced this problem,,
check attachemnt & see certified graphics card for cad ,
either you have to contact GTAC
Warm Regards
Thomas Roman
Machine Designer
hello@Thomas_Roman
Thank you very enthusiastic answer, hope NX 11 next upgrade patch can solve this problem. Like NX 10 as normal. Thanks again.
这是你的显卡不行,不要怪软件,NX软件要求专业级绘图显卡,而不是你现在用的GTX系列游戏显卡。
你可以尝试更新显卡驱动。
推荐使用丽台K620入门级别专业显卡,如果有足够的预算,可以上K2200, K4000.
Hello @finder,
Thanks to Google Translate Smiley Happy @yeqiong is right... This is most likely a Graphics issue, not a NX issue.
The geforce card is no certified. Besides that, you have 2 graphics cards onboard. You might want to disable the intel Card, this might solve the issue. And like before, updating your driver, might also solve if for you.
Hope this info helps,
Kind regards,
Dennis
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
