NX11 Menu/Top Bar Size
Builder
Builder
Hello experts
we ahve NX11 on Lenovo P50 laptops, please refer to attached screen shot on top left hand area where the icons "save", "undo" etc shows very tiny
Attached another screensot on HPZeebok laptop where things seems to be normal,
we tried
File-->preferences-->User inteface pref--> Theme, but didt work
Tried
Menu-->Customize--Icon and tooltips,--> Nothing much changed
GTAC saying update graphic cards, but same is working fine on other laptops with similar graphic cards, hope to hear from experts on forum
3 REPLIES 3
Re: NX11 Menu/Top Bar Size
Your problem may be due to screen resolution. One thing to try is to use the touch mode option which will make everything bigger including the quick access tool bar.
Abe
Hi. I also have same situation. So I uses your solutions and now it's ok. Thank you
Other way can be moving those command to visible area or desired location/bar using Customize (Ctrl +1).
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
