NX11 "save as" menu
Honored Contributor
Honored Contributor
Looking at the "save as" menu in NX11, it's pretty much a rearrangement of the same stuff, into a table format.  My one question is the "reason" column, which I don't see in the help, or what's new files.
What is it, and how can I make use of it?  right now, I can't seem to change it.
-Dave
Re: NX11 "save as" menu
Save As has changed in NX 10 to allow saving of multiple parts in one go.
Another reason displayed in that column could be dependent component/parent or similar.
Generally it should better show what impact saving as of a part is having on other parts.
Like in the old days, where you have to answer multiple save as requests for the parents of a component, if the assembly was open.
Honored Contributor
Honored Contributor
OK, we are going from NX9 to 11, skipping 10.  I thought maybe "reason" was a way to record revision info, ie "what is the reason for the save-as?"
Thanks!!
-Dave
