NX12 Assembly Animation designer
Will you be able to do Rendered Videos with the Assembly Animation Designer?  For example render out different frames using the I-ray render?
Re: NX12 Assembly Animation designer
Siemens Legend Siemens Legend
Siemens Legend
Currently there is no way of rendering the animation with iRay. You can use the other rendering styles such as Trueshade or Advanced Studio.
Paul
