Re: NX12 Measurement, Decimal Accuracy with copy to clipboard
Thanks for the help on this.  I have been out the last couple days.  Thanks again.
While searching for something else, I ran across a journal that lets you select 2 objects, calculates the minimum distance, and copies the value to the clipboard. It is pretty bare bones, only allowing for "minimun distance" type calculations, but perhaps it will come in handy until June.
