NX12 Sheet Template | Header does not move during Sheet Size Change
Hi Guys,
the small issue maybe, but can't find a solution. And I believe you guys can.
I created myself a template for a drawing frame and a header( needed it in german language).  When I now change the size of the sheet my header stays at the position I placed it. Placement was done with an associative point to the frame line.
I expected that the header moves always to the correct position.frame1.jpgFrame2.jpg
Re: NX12 Sheet Template | Header does not move during Sheet Size Change
Problem sovled. forgot the header definition.
