NX12 bad Graphics
Hi All,
i Don't know if more people have this problem.
NX12 looks like its run from a VM.
when starting NX11 on the same system it looks normal.
After installing MP1 for NX12.0.0 its still the same.
I'm using a Quadra K1100M videocard.
Anyone a idea what this could be?
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Re: NX12 bad Graphics
i have found the solution.
It was the setting in visualization performance-> Disable Full Scene Antialiasing that was turned on.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Hi @ruud_vandenbrand
Check if NX is using the intergrated graphics instead of on-board. You can find this in Graphics Properties of the graphics card.
Also, check Visualization Settings in NX.
Another suggestion would be to update your Graphic Card Drivers.
@Ruud_vandenbrand wrote:
Hi All,
Paras Raina, Technical Head, MSC Systems Pvt. Ltd. (India)
NX 12.0.2
Solid Edge 2019
Haha You were a few minutes faster than me. Man Happy
NX 12.0.2
Solid Edge 2019
@Paras_R i just matched the visualization performance settings of NX11 with them from NX 12 and find there the solution.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
