NX13440 module, Can I use Custom Symbols command on drafting mode?
If I using NX13440 module.
Can I use Custom Symbols command on Drafting mode?
Re: NX13440 module, Can I use Custom Symbols command on drafting mode?
NX13440 is for 'Advanced 5 Axis Machining', you need to have the appropriate bundle to work in the drafting application.
Ganesh Kadole
Thanks to your reply!
Have a nice week!
Best Regards.
