NX1847 Part Navigator; show/hide vs suppress
Hi all,
for those starting out with NX 1847;
You probably noticed in the Part Navigator that the suppress checkbox has been replaced with a show/hide.
This can be changed back to what you were used to see:
RMB on the "name" column:
2019-02-11_13.gifNX1847 show/hide in Part Navigator2019-02-11_12.gifNX 1847 suppress checkbox in Part Navigator
It can also be set as a customer default:
2019-02-11_15.gifNX 1847 Part Navigator; Feature Check Box Action
HTH,
Frank
Huysmans Metalen n.v.
2x NX 12.0.2.9 Mach Designer
on Win10 64bit
NX Beta Tester with focus on Sheet Metal
Command Finder is your friend
4 REPLIES 4
Re: NX1847 Part Navigator; show/hide vs suppress
Hi @frank_nx ,
Thanks for sharing it with detailed images. Smiley Happy
There was also knowledge base article published last week about it, Design: Show/Hide from Part Navigator
oops I wasn't aware... Smiley Very Happy
on Win10 64bit
Any idea why the quick unsupress checkbox for features is not working? It works for PMI though, is it a bug ?
Unable to play video. Please try again later.
(view in My Videos)
@m1-G , please attach video to the post, if possible upload part also.
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
