NX1847-What's changed in NX Configuration and NXOpen
Hi Siemens PLM Team,
when NX Continuous Release - Upgrading NXOpen Customization (NXOpen Reporter Tool) will be available on NX1847?
We have planned the transition from NX11 to NX1847 in the final of March. We have lot of custom journals to validate before the switch. In the presentation you have talked of 'NXOpen Reporter Tool'. On beta you have shared a python utility that is not ideal to use and had strange results.
Navigate to https://docs.plm.automation.siemens.com/docs/nx_dev/nx_report/en_US/Whats_Changed.html ?Version=1847 show only NX12 as selectable version to compare.
Thank you...
Using NX11 and NX1847 serie
RuleDesigner PDM
5 REPLIES 5
Re: NX1847-What's changed in NX Configuration and NXOpen
Siemens Genius Siemens Genius
Siemens Genius
Hello cubalibre00,
The tool is available on GTAC under download area:
https://download.industrysoftware.automation.siemens.com/
Use the following Product Filter:
NX > NX 1847 Series > Add-Ons > NXOpenReporterTool
Can you email me your beta testing feedback on why python utility is not ideal to use and also strange results you saw with your custom journals?
Also, if they are journals you don't have to perform any validation and or upgrade steps. Journals should and will execute as-is in an upgraded version of NX. I also would like to know why are you validating journal files?
I've mentioned my email address below, send me the information and I'll respond back.
Shirish
shirish.more@siemens.com
Shirish
Occasionally commands are obsoleted; in this case, journals written for previous versions will not run as-is and will need to be modified for the new NX version.
@cowski1 wrote:
Shirish
Hi @cowski1 ,
it's right. We have custom journals that did not work into NX 1847.
Thank you...
RuleDesigner PDM
Siemens Genius
Hello Cubalibre00/Cowski,
Can you email me your journal files that didn't work in 1847?
I'll investigate and get back with you. Rename your journals to *.txt
Shirish
Hi @ShirishMore ,
sent to you analysis report and our journals, also which are not compatible with NX1847.
Thank you...
RuleDesigner PDM
