NX9 Customized enviroment per user
Siemens Builder Siemens Builder
Siemens Builder
a Customer that is bound to adquire an NX 9 license ask about how several users can access to NX with each custom envoroment (they refer to menus,bar,graphics such as bakground ,etc).
I suggest using different roles but I can not get background related to each user maintain.
Can I get from You any ideas or document to know how to customixe such envioroment?.
Thank in advanced for your help.
Regards.
Re: NX9 Customized enviroment per user
Esteemed Contributor
By default, user level customizations (i.e. button layout, etc.) are stored in UGII_USER_DIR.
Open the syslog (Menu -> Help -> [NX] Log file) and search for UGII_USER_DIR
If that doesn't show up, search for "user.mtx"
That will tell you what folder is being used for user-level customization (typically something like "C:\Users\(insert username here)\AppData\Local\Siemens\NX(insert nx version here)"
You might want to look (over in the programming & customization forum) for the (ex) Rob Cohon customized environments.  Lots of info in there about how to share (or not) your customized envirnment.
Background color is a characteristic of the part file, so if you're using any sort of template you'll need to edit them to change the background color.  Now if you always use the File -> New -> Blank option then you can change that in Customer Defaults at Gateway -> Visualization -> Background Color and you can set up custom Customer Defaults for each user.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
