NX9 TC10 Compare differences between Assembly ItemRevision from NX
Siemens Builder Siemens Builder
Siemens Builder
Hi Experts,
It is possible to compare Assemblies in Nx9 Integration TC10?
I tried to use Prepare for Compare (in NX}but the customer want compare
Assembly and not Components(or Part) only.
They want compare to extract differences between Assemblies Item Revision that have an
Baseline Status in TC.
I do not know if there are other methodology to get the desired results but when I try to do this compare
I can not get Assemblies Itemrevision that have a Baseline Status in TC.
Any idea about it  ?
Thanks in advanced for your help
Re: NX9 TC10 Compare differences between Assembly ItemRevision from NX
For 3D geometry comparison you can use 'Model Compare' within NX.
To compare the assembly structure in Teamcenter, Send one item revision to structure manager. Split the window and send second item revisions to structure manager. There you can configure the column 'Item Revision Status' to compare the difference. You can also set the Revision rule in individual window as per your requirement. I have shown it as an example.
Further you can also use 'Graphical BOM Compare' within the structure manager. Refer the attached document.
Ganesh Kadole
Siemens Builder
Thanks a lot Ganesh....
let me insist on how to compare Assembly Revision in NX and how to compare Assemblies in NX that have Status.
Is there an easy way to do this without use visualization and with all components in Assembly?
Kind Regards,
Fidel
