NXOpen-Query Part's symmetry plane or symmetry axis
is there any api or method to get the symmetry plane of part (if it has one )?
Re: NXOpen-Query Part's symmetry plane or symmetry axis
You're more likely to get an answer in the Programming/Customization forum.
There are SNAP and NX/Open functions that calculate moments of inertia and principal axes. And, if an object has a plane of symmetry, then the normal of that plane is a principal axis.
You could experiment with the interactive mass properties function, and confirm that knowledge of the principal axes helps with your problem.
Then, if you want to automate, post a question on the Programming/Customization forum.
山田
yamada
Thanks a lot. I'm new to the forum. .My mind was limited to the NX model function ,your answer is very helpful for me.
