Name loc for assy constraint
Honored Contributor
Honored Contributor
User would like to move the "Name" they assigned to an assy constraint, so that it is on the left side, and they don't have to have the pallett stretched so far across their screen.
-Dave
NX1867(if it had versions) | Teamcenter 11.6 | Windows 10
3 REPLIES 3
Re: Name loc for assy constraint
Dave,
In the assembly navigator, MB3 on 'Descriptive Part Name'.
From the pop up list, choose Configure
Click the General tab on and assembly navigator properties dialog
In the Display Constraint Names drop down list, select 'User and System', then apply.
Go to the Assembly Navigator Properties and change the Display Constraint Names to "User and System":
Regards, Ben
NX (v17 - 1876) | Teamcenter (9 - 12)
'Configure' is in the 'Columns' flyout list.
