Need in-depth details for NX Freeform 1 (Basic)
Greeting everyone!
As the title says, I need details on Basic freeform (freeform 1) available in NX. Just a document listing all the features (list of commands, primarily surface commands) in Freeform 1 would be very helpful.
I browsed through the partner portal but couldn't find any relevant document. If it's hidden in there, please give me the link.
Paras
Paras Raina, Technical Head, MSC Systems Pvt. Ltd. (India)
NX 12.0.2
Solid Edge 2019
5 REPLIES 5
Re: Need in-depth details for NX Freeform 1 (Basic)
I guess I wasn't very clear because I didn't get any response.
Actually a customer of ours needs very precise in depth comparison between Freeform Basic & Advanced versions in the NX. There are a set of commands (basic ones like swept, through curve mesh, bounded plane, etc.) in Freeform 1. I just wanted a complete list of the commands present in NX freeform 1 so that I could get a better picture of the two versions and hence help the customer.
If someone from Siemens or a parter can help me with this, I'd be very thankful.
NX 12.0.2
Solid Edge 2019
Paras the commands in freeform1 are:
Bounded Plane
Thicken Sheet
Variational Sweep
Ruled
Through Curves
Through Curve Mesh
Swept
N-Sided Surface
Offset
Trimmed Sheet
Trim and Extend
Reverse Normal
Boundary
Untrim
Scott
@ScottFelberThanks! Can you also give me the list of features in freeform advanced?
& I'm just curious, where can I find this document? Smiley Frustrated
Paras
NX 12.0.2
Solid Edge 2019
I have a list I've kept to answer this sort of question for my customers.
Not exactly up to date but it should be pretty accurate.
Image below is a snapshot of what I have found.
Anthony Galante, Senior Support Engineer
PhoenxPLM
24 versions of NX installed: NX4 to NX12, plus TC11.2
@PhoeNX_SupportThat's quite helpful. Thank you very much.
NX 12.0.2
Solid Edge 2019
